Tractor Talk Discussion Forum
ford 600 help
Stanley A. Jone
04-10-2004 10:42:46
I just drove tractor to garage ,,pulled plugs cleaned them,,checked rotor ,,points everything looks ok ,,,NOW,,I have no spark,,what in heck,,
thank you
jhill
04-11-2004 08:15:18
 Re: ford 600 help in reply to Stanley A. Jones Sr., 04-10-2004 10:42:46
I have had to file new points to get a spark on my 600. They can get an oxide coating on them which will prevent spark from occiring.
Geo in SD
04-10-2004 20:31:49
Looks like you have checked everything pretty well, but one more thing to check would be that little insulator where the wire comes out the side of the dist body to the coil. There is a metal strip that connects the points to the stud and I've seen this strip get pushed against the dist body and short out. Also, there is a little insulator inside the dist body that the head of the stud seats against. I've seen these look pretty good, but still leak current. Also good to clean everything up real good, as dirt can cause a short, also.
mark
04-10-2004 13:54:13
Didn't forget to put the rotor back in did you?
rod
04-10-2004 16:22:00
 Re: Re: ford 600 help in reply to mark, 04-10-2004 13:54:13
Glad I wasn't the only one who thought this.
rod
04-10-2004 12:33:52
When you say "checked", did you adjust the points?
Stan Jones
04-10-2004 12:49:49
 Re: Re: ford 600 help in reply to rod, 04-10-2004 12:33:52
at first i never touched them,,and still had no spark,,I did put a new set in and still no spark to plugs
Stan(PA)
04-10-2004 14:15:23
 Re: Re: Re: ford 600 help in reply to Stan Jones, 04-10-2004 12:49:49
I'm sure you did, but just in case....Did you set the point gap with the rubbing block on the high point of the cam? Did you replace the condenser? If so, new condenser could be bad, causing very weak spark.....Stan
04-10-2004 16:55:43
 Re: Re: Re: Re: ford 600 help in reply to Stan(PA), 04-10-2004 14:15:23
no i didnt replace condensor and yes i gapped points on high side,,and yup the rotors in
WBinPA
04-10-2004 17:07:18
 Re: Re: Re: Re: Re: ford 600 help in reply to Stanley A. Jones Sr., 04-10-2004 16:55:43
There is a small piece of metal which fits between the distributor and the rotor which commonly falls out and gets lost when the rotor is removed. If you do not have it, you will see spark at the coil but not at the plugs. If you lost it, you would be the millionth person to do so.
walt
04-11-2004 06:19:12
 Re: Re: Re: Re: Re: Re: ford 600 help in reply to WBinPA, 04-10-2004 17:07:18
Good catch. Completely forgot about it. Got the same motor, and it will not run without it. Your New Holland has it, but $5 for a little tiny piece.
