Tractor Talk Discussion Forum
John Deere generator diagnosis - how?
Damon
04-10-2004 16:54:35
Hello - I have a JD 430 (1950's) and am only getting 6v at the terminals when it is running. We polarized the generator but still not more than 6v.. how should we determine if the generator is dead?
buickanddeere
04-12-2004 05:37:25
 Re: John Deere generator diagnosis - how? in reply to Damon, 04-10-2004 16:54:35
If you had the operators and service manuals you would know that all two cylinder spark igniiton Dubuque Deeres were 6V positive ground. 1-800-522-7448 for the books.
Reido in MO
04-11-2004 08:46:45
Pull the Neg battery cable off while the tractor is running. If it dies, the Gen is no good.
Jeff
04-11-2004 06:56:14
Have you checked the tag to make sure that is isn't a 6v generator? If it is supposed to be 12v someone couldhave changed it and not known the difference.
Keith
04-11-2004 00:10:11
Check out this website. go to #35 Wire Diagrams then click on photo 15 or 16.. will give you some good info.
Link
Hope this will help Keith
Mr b
04-10-2004 20:34:03
Take it off the rig and bring it to the nearest shop. They'll test it for ya
gene b
04-10-2004 17:43:52
Ground the field and then if shows charge the reg is bad. You can run it with the field grounded.
