Tractor Talk Discussion Forum
teeth on flywheel
Bill from senec
04-12-2004 19:26:23
hi, i am restoring a 1948 farmall cub does anyone know if you can have someone sharpen the teeth on a flywheel or is it just bad and you have to have it replaced thanks for any help bill
John *.?-!.* cub owner
04-12-2004 19:35:51
 Re: teeth on flywheel in reply to Bill from seneca , il, 04-12-2004 19:26:23
Bill, you can easily do it yourself with a 4 or 4 1/2 inch hand grinder. The teeth will only be worn in 2 places opposite each other, and you can easily reshape them to approximately match the adjacent teeth. I reground the teeth on my 48 working cub about 9 years ago, and it has been working great ever since. Also check the teeth on the starter drive, they get blunt also. You can also remove the ring gear from the flywheel and rotate it 1/4 turn and reinstall, but the grinder is easier.
BILL
04-16-2004 02:11:49
 Re: Re: teeth on flywheel in reply to John *.?-!.* cub owner, 04-12-2004 19:35:51
thanks john for all your help for the most part it worked better than before great to hear that you have a cub look for me down the road theres more things i need to know about this cub thanks bill from seneca, il
