Tractor Talk Discussion Forum
Ford 2n backfiring
Jim
04-17-2004 17:59:34
My 2N is back firing and i dont know what the problem is. First gear has no power going up hill. The tractor shuts off sometimes for reasons I dont know. I cleaned the fuel bowl and fuel line to the carb. Makes no difference. I do have good gas flow after doing that. Any suggestions?
RAB
04-18-2004 06:58:47
 Re: Ford 2n backfiring in reply to Jim, 04-17-2004 17:59:34
If you are saying, there wasn't a good flow before, then your problem is likely that the carb jets need attention as well as the float bowl etc. You are tight on information. Like the condition they were in before you cleaned them. Like is there good fuel flow from the carb drain immediately after it shuts off. Like what brought this on - standing over winter, or over one run or over the past 6 months running.
I would suggest you give it, or get someone to do, a good service. You should then know if everything is in specification or not.
I would also suspect the ignition system
Regards, RAB
DL
04-17-2004 20:08:53
a wise old mechanic once told me 99% of carburetion problems are ELECTRICAL!!! check your electrical system!!! I'd bet money your points are FRIED! ... but also check condenser, plugs & wires, rotor & cap... I'll bet if you replace all the above, your "N" will run like a top! Regards!! D
