Tractor Talk Discussion Forum
2010 will not go in reverse
matt
04-19-2004 11:47:53
My wifes father has a 2010 gas all foward gars work fine. But none of the reverse gears work. After taking off the gear box cover nothing look broke. On the clutch fork that controles the reverse is a round object that has three fiber plates in it.this unit slides with in 1/4" of ingageing reverse. After removing the external linkage you still can not get reverse it just grinds. please help.
Brokenwrench
04-19-2004 13:16:03
 Re: 2010 will not go in reverse in reply to matt, 04-19-2004 11:47:53
That is your reverse synchronizer. From what you are saying the splines inside are worn to the point it won't engage anymore. It will have to be replaced which will require you splitting the tractor,and removing the shaft.
