Tractor Talk Discussion Forum
Looking for a tractor for use in a vineyard
Steve in Minnes
04-19-2004 13:11:47
I'm trying to find a reasonable priced tractor for use around a 20-acre vineyard in Minnesota. Primary uses would be mowing grass, moving compost piles around, and ideally running an auger and/or post-pounder. Any suggestions?
glenn
04-20-2004 19:43:09
 Re: Looking for a tractor for use in a vineyard in reply to Steve in Minnesota, 04-19-2004 13:11:47
A massey ferguson 230 or 235 would work very nice . You need a tractor with auxillary hydralics to run your pounder.Older fords dont have this option.
J (NH)
04-20-2004 17:18:26
All comes down to how much you want to spend. An IH Model H or a 300 utility is a good general use one or maybe a Ford 800 if you don't want to spend a ton of cash. But if you can afford it you might want a newer 4wd 30 hp-plus with a loader. As far as that goes, I'd shop around and go with what feels best and who has the best dealer support around you. I run older cheaper ones and I'm happy but I don't run them 10 hrs a day.
Irv
04-19-2004 19:11:11
Darn, - You folks have vineyards in Minnasota? I thought it would be too cold up there. Irv
Steve in Minnesota
04-20-2004 11:12:34
 Re: Re: Looking for a tractor for use in a vineyar in reply to Irv, 04-19-2004 19:11:11
Yes, we have a quite a few vineyards and wineries in Minnesota. In fact, I'm willing to part with a case or two of 100% Minnesota wine if helps get a deal on a tractor...
jim
04-19-2004 15:07:46
Are you aware of the vineyard special tractors which have been built especially for vineyards ?
They are very narrow and have shielding around the wheels in order to prevent damage to the vines and trees. In vineyard and orchard areas here in Ontario , these models (used) are fairly reasonable because of their limited use.
Steve in Minnesota
04-19-2004 19:06:07
 Re: Re: Looking for a tractor for use in a vineyar in reply to jim, 04-19-2004 15:07:46
Yes, I have seen vineyard-specific tractors, but that is not what I need. I'm just looking for a general purpose farm tractor - just trying to get some free advice.
Sharon
04-19-2004 15:00:33
Have you checked out Biewer's Tractor Salvage up by Fargo? www.salvagetractors.com
