Tractor Talk Discussion Forum
1070 Case powershift problem.?????
hockeycoach
04-20-2004 11:11:28
I have a 1978 with a powershift that is slipping in second and has poor hydraulics in that gear ...1st and 3rd are okay...Does anyone have any suggestions as to the problem here...Thanks.
twopop
04-20-2004 19:08:20
 Re: 1070 Case powershift problem.????? in reply to hockeycoach, 04-20-2004 11:11:28
I would think that the clutch piston o-ring is leaking and you are losing hydraulic pressure.the unit will need to be split and repaired.it might also be leaking 0-rings on the supply tubes.it doesnt need to be split to repair those.
