Tractor Talk Discussion Forum
cub cadet 2130 p.t.o. clutch
jay
04-22-2004 08:39:55
while mowing my pto kicked off while backing up ,after re-engaging ,it kicked out again,after checking it out i found the bolt that is mounted in front of engine block and holds p.t.o in place was sheared off,allowing p.t.o. to spin on shaft and all of the wiring pulled out and wraped around shaft ,tractor was still running,but after fixing wiring,motor will not run,do i need a new p.t.o.,and how hard is it to install?please help!
Kenneth Belile
04-23-2004 09:00:18
 Re: cub cadet 2130 p.t.o. clutch in reply to jay, 04-22-2004 08:39:55
I am a cub cadet Commercial Power Dealer.
Manuals available at Cubcadet.com, pto is a beast to change if you don't know what you are doing. Suggest you fine local mechanic for the replacement. Also safety switch connected to PTO will shut down engine if PTO is no functioning normally.
Kenny
