Tractor Talk Discussion Forum
going nuts on restored cub
bill from senec
04-22-2004 18:56:40
to many problems on getting it right i completly restored this cub from the bottom up took it completly a part to paint did new seals and gaskets rebuilt the motor,rebuilt the carburetor yet i am having to many problems on getting it started i ave check the timing over and over at tdc i ave check the magneto many times seems to be in time i can get the tractor runnig but i have to advance the magneto all the to the motors side plus have to have the gas lever wide open and choking the heck out of it is there such a thing as a bad rebuild carburetor kit i have lots of gas pouring out of the air cleaner side of the carburetor is this normal yet my spark plugs always seem dry never wet with gas when i do get the tractor started and it smoothes out it sounds fine seems to run fine until i try to use the hydrulics to try to use the mower the rpms drop big time and the tractor wants to die i know this is a very long story but like i said i think i ave done all the right things and i am going just freaking nuts anybodys input would be greatly appreicated thanks bill
Bill from Seneca, IL
04-24-2004 18:02:35
 Re: going nuts on restored cub in reply to bill from seneca, 04-22-2004 18:56:40
Hi,just like to say thanks to everybody that e-mailed me. Was going nuts on restoring my cub tractor. Everybodys imput really helped. I went back and found out the governor was not in time. Reset the timing marks on the governor now the tractor runs fine. Thanks everybody, Bill
49 Cubber!
04-24-2004 04:49:11
If you having to advance the mag,your timing is off somewhere.Whcih Seneca are you from,SC?I live near there and may be able to help.
Cub nuts
04-23-2004 06:58:46
Go to the Farmall Board here at this site(YT). There are several Cub nuts that hang out there.
Robert Geuy
04-23-2004 04:15:01
 Re: Re: going nuts on restored cub in reply to evielboweviel, 04-22-2004 19:27:05
Double check your valve clearance. If just one valve is tight it will act this way.
