Tractor Talk Discussion Forum
Key left on--Pertronix
Dan
04-24-2004 08:38:38
What damage might occur if key is left on and what would the engine run like becouse of this situation?? This is on a 4020 Lp 12v Pos. grnd.
Thanks ahead of time.
Bob
04-24-2004 09:10:09
 Re: Key left on--Pertronix in reply to Dan, 04-24-2004 08:38:38
The possibilites are:
1.) Burned out Pertronix unit... no spark at all.
2.) Coil damaged from overheating... poor spark, hard starting, backfire, miss under load.
3.) Coil completely burned out... no spark at all.
4.) Coil AND Pertronix burned out.
Dan
04-24-2004 13:39:40
 Re: Re: Key left on--Pertronix in reply to Bob, 04-24-2004 09:10:09
This is a Ignitor model// would it be better to replace With IgnitorII unit they say it has some protection against key on.
Any Ignitor II users out there??
Jon H
04-24-2004 11:06:01
I wonder if Pertonics has a power down system like many stock electronic ignition systems that go to low or no power flow through the coil if the engine is not turning over? I suppose turning on the ignition without starting the engine and checking for any coil heat after about 5 min should answer the question. I don't remember any stock electronic ignition system being damaged by leaving the ignition on,even untill the battery is dead. I have converted my 4020 gas to Chrysler electronic ignition. I will do the coil heat test and report back.
Bob
04-24-2004 15:23:18
 Re: Re: Re: Key left on--Pertronix in reply to Jon H, 04-24-2004 11:06:01
JonH:
Pertronix DOES NOT POWER POWER DOWN.
(Per their website, and my experience.)
Pertronix II DOES power down.
Jon H
04-24-2004 19:46:16
 Re: Re: Re: Re: Key left on--Pertronix in reply to Bob, 04-24-2004 15:23:18
Thank's for the info Bob.
I have no experience with Pertronix and was curious of the design of their control module. Sounds like Pertronix II might be a worthwile upgrade. Is the Pertronix/Pertronix II triggered by a magnetic pickup or does it use a photo cell/shutter wheel system?
The Chrysler electronic ignition system on my 4020 and an early Ford duraspark system I have do draw power with the ignition on and engine not running. I did not notice any coil heating after about 10 min,but the ballast resistors were too hot to touch.
Bob
04-24-2004 19:51:18
 Re: Re: Re: Re: Re: Key left on--Pertronix in reply to Jon H, 04-24-2004 19:46:16
Jon and Dan:
Have you been to their website?
There is a phone # for the factory there. I have called them a number of times for odd applications, and they have been very helpful.
I'm sure they could help you locate a dealer, also.
http://www.pertronix.com/
Dan
04-24-2004 19:40:25
Where are some places to look for the IgnitorII series// to purchase- I see they only have the Ignitor on this site
Allan
04-24-2004 08:43:54
Kinda hard on points, if so equipped; but probably will just run the battery down.
Allan
