Tractor Talk Discussion Forum
Applying rubber tread to steel wheels
Brad in Wiscons
04-26-2004 13:14:33
Hello, gonna put rubber around a set of rear steel for a GP.Was wondering as to how to do it, any tricks for cutting old tire? Any other options to make er Blacktop worthy? It is gonna be a parade unit,no plowing no more for her. Thanks
Bob M
04-27-2004 05:06:53
 Re: Applying rubber tread to steel wheels in reply to Brad in Wisconsin, 04-26-2004 13:14:33
Brad - A buddy of mine cuts the tread off using a 7-1/4" circular saw with either a carbide demo blade or an abrasive cut off blade. It's nasty - generates enormous volumes of smoke and of black dust. Must use eye and respiratory protection! But it's fast and if you have a steady hand can result in neatly cut tread strips.
He did a JD D using old chevron tractor tire treads on the rear. Looks good and works great - even has acceptable traction on wet grass. He also rubberized a steel wheeled 2 bottom plow using treads cut from old motocross motorcycle tires.
