Tractor Talk Discussion Forum
6 to 12 v Conversion of Ferguson
Ron Feltes
04-27-2004 18:32:54
I have just replaced the 6v generator of a Ferguson with a one wire alternator, I put in a 12v battery and I bought a 12 v coil and plan to wire it with now negative as ground.Do I need to replace points and condenser? Thanks for your help.-Ron
Steve-Maine
04-28-2004 04:55:37
 Re: 6 to 12 v Conversion of Ferguson in reply to Ron Feltes, 04-27-2004 18:32:54
A few years ago I convereted a Minn Moline to 12 volt and left the 6 volt starter in. Sure started good and had no problems. Good Luck
Jon H
04-27-2004 20:39:24
Condenser and points will be fine. There is no such thing as a 6V or 12V condenser. When the points open,there is a voltage spike of several hundred volts induced in the primary winding which the condenser easily absorbs,so it does not care what the system voltage is. The wiring posted below is very good.Make sure you connect the coil neg terminal to the distributor for a neg ground system.
Ron Feltes
04-28-2004 03:56:10
 Re: Re: 6 to 12 v Conversion of Ferguson in reply to Jon H, 04-27-2004 20:39:24
Thank you that helps a lot. -Ron
mj
04-27-2004 19:45:06
third party image
Here is one of Bob Ms' diagrams for a Farmall 12v conversion but it is basic for most older tractors....click on the link for more schematics (#35 on the list).
