Tractor Talk Discussion Forum
farmall 544
Doug
04-28-2004 07:38:53
looking at a 544 gas with wide front end I was originaly looking for a 560 diesel but was told they were hard starting in winter and that the 544 was about the same H/P I need the tractor to run a haybine and square baler. any sugestions?
Jimmy King
04-28-2004 12:19:03
 Re: farmall 544 in reply to Doug, 04-28-2004 07:38:53
A 544 gas is rated about 52hp a 560D 63hp, I had a 544 gas once they like gas a 560D will use a bout 1/2 as much fuel. A 656D also 63hp would be a better choice in my opinion. I have a 460D almost the same as 560D eng. same block longer stroke. No 2 a 544 gas is not a sleeved engine. must be bored when OH. 656 could get 3point 560 is 2 point. Any Diesel you should have a block heater and keep the starter and batterys in top shape and they will start in winter and not be cold natured like a gas once they start, although a Diesel will not run at its max. until warmed up to operationing temp.
