Tractor Talk Discussion Forum
Electrical problem
Dave Meskenas
04-30-2004 11:00:17
I have a New Holland TC29, I installed a new battery this spring. Since installing the new battery, my tach and hour meter does not work. The red alternator light stays on all the time. The tractor starts fine, but the tach and hour meter does not work. Any thoughts?
RickB
04-30-2004 14:12:23
 Re: Electrical problem in reply to Dave Meskenas, 04-30-2004 11:00:17
All your symptoms point to a nonfunctioning alternator or one that is not connected to the rest of the electrical system. Some NH compacts have a smaller red wire connected with the positive battery cable that connects to the alternator. If your old cable had this , does the new one? Check voltage at the battery with a VOM both running and not running. if the readings are the same, your alternator is not charging the battery, which is indicated by the red alt light being lit.
