Tractor Talk Discussion Forum
1942 ? 9n ford steering box lube
Farm Boy
05-02-2004 06:31:28
I have looked to find were to check the steering box lube and I see no pipe plug . I would like to put grease in it because the seals are shot. And could someone tell me for sure what the age of this old boy is ser# 87207
Duner Wi
05-02-2004 19:29:39
 Re: 1942 ? 9n ford steering box lube in reply to Farm Boy, 05-02-2004 06:31:28
Your serial # says it is a 1941 according to R&I and then serials #s on left column.
Pretty sure the steering gears are lubed by splash from the transmission gears and no separate fill plug for the steering gears.
Farm Boy
05-03-2004 21:18:06
 Re: Re: 1942 ? 9n ford steering box lube in reply to Duner Wi, 05-02-2004 19:29:39
Thanks to all
Ray,IN
05-02-2004 21:59:53
Duner is right. The splash system is a rather crude method of oiling anything above slow moving gears, and the steering "gears" usually suffer form a lack of lubrication. I've seen disassembled steering boxes that are rusted all over inside from lack of lubrication. This is because moisture condenses on the exposed(above oil level) dry metal parts.
