Tractor Talk Discussion Forum
Cub LO-Boy
Ricey06
05-02-2004 18:03:20
I have a '62 Cub. It ran great for 5 yrs. When I started to use it this spring, it started to cut out? I thought maybe bad gas? I cleaned the bowl & added fresh gas. Now it won't even juice the lites or click the starter? The battery is only a 2 yr. old "intstate" I only have a 12 volt charger. Hope somebody can tell me why the tractor drained the battery?
Gene Davis (Ga.)
05-02-2004 20:19:05
 Re: Cub LO-Boy in reply to Ricey06, 05-02-2004 18:03:20
Sounds like the battery voltage got so low it would not fire the ignition. The regulator probably will need to be repolarized when you recharge the battery.You need to make sure the generator is charging when you crank it again.
