Tractor Talk Discussion Forum
B250 gearbox lube change?
roy
05-05-2004 07:16:18
Hi.. A couple Q's re gearbox lube changing..
Q1
I have a B250 & was wondering about changing out the old gearbox lube. I had the PTO
gear repaired a few years back & I think 80W90
gear oil is what is in there now.. Is that the best/proper fluid to use?
Q2
How to get the right level? I noted three plugs,
one one top right next to gear shift [for putting lube in], one at the bottom [presumably the drain] and a third just beside the right foot-plate on the frame right beside the brake pedal.... Is that the level to fill too? [close the drain after dumping old oil,
refit drain plug & fill until oil starts coming
out this port [on level ground I would assume]]?
Like to do it right the first time!
thanks in advance if anyone can advise!!!
Roy
