Tractor Talk Discussion Forum
Replacing the starter on a ford 8n
Rick Papiez
05-05-2004 13:58:57
How do you remove the sratrer to replace it. I went to start the tractor I hit the starter heard a snap now nothing. It doesn't do anything now but clicks
jstpa
05-05-2004 18:58:02
 Re: Replacing the starter on a ford 8n in reply to Rick Papiez, 05-05-2004 13:58:57
Rick,
If it just clicks once, first try what gene said.
If it is a steady clicking "machine gun " type clicking as you hold the switch in start then you have low voltage, possibly a bad battery or bad cables. Hope this helps, jstpa
Gene Davis (Ga.)
05-05-2004 17:58:37
Ford starters are bad about locking up when they get wear and age on them. Try putting tractor in high gear and rocking it backwards to see if the starter will disengage from the flywheel.
