Tractor Talk Discussion Forum
Problem getting fuel through injector pump
Herb
05-05-2004 14:22:34
I am not getting any fuel from my injector pump to the injectors. I have fuel from the bottom bleader valve and have fuel from the return that goes to the filter bowl but no fuel comes out of the connections to the injectors. Some have said that it is the butterfly valve on the manual shut off. If anyone has any ideas I would appreciate you comments.
RAB
05-05-2004 22:42:10
 Re: Problem getting fuel through injector pump in reply to Herb, 05-05-2004 14:22:34
I think you will find two bleed valves on the CAV pump. Both need clearing of air, as well as having the stop control in the run position.
Regards, RAB
Philip Jensen
04-16-2006 16:54:51
 Re: Re: Problem getting fuel through injector pump in reply to RAB, 05-05-2004 22:42:10
Hi RAB, You mention 2 bleed valves on the CAV pump. I know about the obvious one on the side of the unit. There is the overflow on the cover. The level indicated is equal to fuel in tank. I have blown and sucked on this line. Yuck. Nothing. Herb's problem describes mine perfectly. In time gone by, opening the side bleed would indicate the pressure of the pump which visible by removing the end plate. This plate accepts the fuel from filter. There is no indication of pressure from the side bleeder. I hope you can wade thru all this. Who ever designed this dude and the way it is mounted needs a cranial examination. Be happy to oblige. Thank You Philip Jensen
youngster
05-05-2004 17:01:40
try blockin off the return line and see if it puts fuel through th pump
Wardner
05-06-2004 16:54:30
 Re: Re: Problem getting fuel through injector pump in reply to youngster, 05-05-2004 17:01:40
I do just the opposite. I put a vacuum on return line and crank. If you don't mind the taste of diesel fuel, it can be done with your mouth. I usually use a peristaltic pump with a small motor.
