Tractor Talk Discussion Forum
TSX 403 carb adjustment
polk crawler
05-07-2004 08:03:02
Any advice on adjustment of two screws on the TSX 403 will be appreciated. Throttle idle screw setting no problem but there are two others I am sure need attention. Engine smokes a bit when starting which suggests screw settings are off.
Thanks
PC
polk crawler
05-08-2004 19:22:43
 Re: TSX 403 carb adjustment in reply to polk crawler, 05-07-2004 08:03:02
Bob M: Thanks for the reply but...two screws, one about 1/4" dia head that has slot for screwdriver.\ Second screw about 1/2" diameter which can be moved between thumb and finger. That one is toward front of carb facing front. Which is idle mixture screw..smaller or larger?.
PC
Bob M
05-10-2004 04:13:54
 Re: Re: TSX 403 carb adjustment in reply to polk crawler, 05-08-2004 19:22:43
PC - The one with the thumbscrew adjusts the HIGH speed mixture! ...Bob M
Bob M
05-08-2004 14:48:06
PC - I'm not familiar with that particular Marvel-Schebler carb model. However the TSX series in general proceed like this:
First make sure everything else (ignition system, spark plugs, valve lash) etc is in good shape and adjusted to spec. Otherwise dinking with the carburetor is effort wasted. Then:
1 - Start the tractor and let it warm up fully. (10 - 15 minutes). If there is any evidence of carb icing (frost on the exterior) wait for a warmer, dryer day to do your adjustments. Make sure the choke is fully open before proceeding.
2 - With the engine at idle, adjust the carb idle mixture screw back and forth. Find the spot where the engine idles fastest/smoothest. If necessary slow down the idle with the idle stop screw. Then repeat the idle mixture adjustment, leaving it again the fastest/smoothest idle.
3 - Next quickly accelerate the engine by grabbing the governor to carb throttle link and pulling it open sharply. If the engine stumbles or stalls, open the high speed screw about 1/4 turn at a time and repeat. If the exhaust smokes black when you snap the throttle, turn the screw IN about 1/4 turn at a time. Once you find the spot where the engine picks up without stumbling or making black smoke, OPEN the high speed screw an additional 1/8 to 1/4 turn.
4 - Finally repeat the idle mixture adjustment once more - it may have changed a bit.
Hope this helps!
