Tractor Talk Discussion Forum
Jacobsen Tractor
Bob Williams
05-15-2004 08:07:28
I have an old Jacobson tractor which has been operating well over the last several years. This week I was using it for the first time this year. Although I got it started fairly easily the electric clutch would not activate. I shut down and checked to make sure everything was free. I started up and the clutch engaged. After several minutes of cutting I noticed significant smoke coming fron under the engine compartment. After shutting down I checked the engine compartment and found almost all of the wiring insulation entirely burn from the wires. Is there anything that I should look for or just assume that it was the result of a direct short to ground? Where can I can get a replacement wiring harness, ignition switch, and clutch switch? Should I take any speccial precautions in rewiring?
Tony
05-24-2004 20:55:56
 Re: Jacobsen Tractor in reply to Bob Williams, 05-15-2004 08:07:28
You guys should try this site. Someone ther may have what you're looking for.
http://groups.yahoo.com/group/Jacobsen_Ford_Garden_Tractors/
R-man
05-16-2004 15:13:20
Bob, I just rebuilt my GT-16 Hydro this past winter. When I took the engine apart I found huge chunks of insulation missing from the front of the electric clutch coil. Because it had been working fine when I took it apart I just covered it with finger nail polish and put it back together. It worked ok till yesterday.It had rained quite hard all last week. The tractor started fine but every time I tried to engage the deck the engine killed.I suspected moisture was shorting the system so I ran the engine for 5 minutes to dry things out. Worked fine after that. I wish I knew where to get those coils. Sorry I couldn't be more help.
