Tractor Talk Discussion Forum
timing chain ford 801 select o matic diesel.
Hal Kravcik
05-16-2004 12:50:01
I'm looking for any help on how to replace the timing chain on my ford 801 select o matic diesel. Its a 1961.
tlak
05-16-2004 16:20:10
 Re: timing chain ford 801 select o matic diesel. in reply to Hal Kravcik, 05-16-2004 12:50:01
Should be the same as gas, if so by the year model it will have a press on gear on the cam. You might find somebody with experiance changing press on in the tractor. On mine the timing cover would not come out pass the the crank with out some relief. You can gain this by loosening the big front axle support nuts and sliding it forward some. The timimg cover is simple to remove just make sure to get the bolts up from the oil pan. You might pull your hydraulic pump and check the gear that runs it. It mounts to the back of the cam and if worm you have to split the tractor to replace it.
Dieselrider
05-16-2004 15:34:56
If you have a 1961 801 it shouldn't have a timing chain but two timing gears inside the front of the motor. The crankshaft gear runs the camshaft gear, thus no timing chain. The book says to split the tractor to change either gear but, I think, after I went through that proceedure, you might be able to pull the gears from the front without the split. Good luck.
