Tractor Talk Discussion Forum
hyd cyl cleanup
Farmer in the D
05-16-2004 14:52:59
how do you clean up a dirty hyd cylinder? the inner shaft is not badly pittted and only surface rusted. whats your method of cleaning them up? what would I want to stay away from?
Larry NE IL
05-16-2004 19:13:45
 Re: hyd cyl cleanup in reply to Farmer in the Dells (WI), 05-16-2004 14:52:59
I agree with Nb. Cowman. If it is scored or pitted, you are wasting your time. With hydraulic systems, wherever oil leaks out, dirt leaks in. Be a shame to mess up the hyd. system for the cost of a $50.00 ram at Farm and fleet.
If it's a "special" ram, best to take it to a hyd. shop, have them "true" it and rechrome. It will be like new. Regards, Larry
joe e-tx
05-16-2004 18:15:09
well i bougth a mf 40 ind loader with rust on polish shaft and first thing i did was BP blaster took off rust now i have small pock marks to smooth out and i dont worry about small fluid loss
Ron in AR
05-16-2004 16:51:26
Here's a trick I've used often to polish various metals... get hold of a heavy piece of leather, cut a 3 to 4 inch flat round out of it and attach it to a drill arbor. Polish away! Use the steel wool mentioned to take off the rust first though. But that leather will make 'er shine like new! I've used it on everything from bumpers to jewelry (made up a little one for my Dremel).
rustyfarmall
05-16-2004 17:31:32
 Re: Re: hyd cyl cleanup in reply to Ron in AR, 05-16-2004 16:51:26
Ron, I like that idea, plus it will give me a good use for my worn out boots.
rustyfarmall
05-16-2004 16:10:46
The safest way I can think of would be to use steel wool, size 4-0. I have done this on an older cylinder I have, the ram shined up pretty good, I haven't been able to test it because I can't locate any new packing for it.
nebraska cowman
05-16-2004 15:25:11
I can't work without the wire wheel on the bench grinder but if you are talking about the shaft that goes in and out it must be perfectly shiny or you will never keep seals in it.
