Tractor Talk Discussion Forum
magneto trouble
bullrunner
05-18-2004 05:44:31
Before I purchase the points and condensor for my Wico series C magneto, is there a way to tell if thats the problem? I am not getting any spark any the wires look to be in good shape. Can something other than the points or condensor go bad? How can I test it?
Thanks
Larry from MD
05-18-2004 09:26:29
 Re: magneto trouble in reply to bullrunner, 05-18-2004 05:44:31
Well the coil is the other big thing to go bad.If you have a voltmeter that reads on a low scale you can hook the leads up to the coil in the mag(one is grounded) and spin it.You should get a bump reading on the scale of 2 to 3 volts.If you know the coil is old and not been replaced in a long time its best to change it anyway,when you get the engine running it will stress the coil and it will start to break down after a small amount of use.
Bullrunner
05-18-2004 10:55:07
 Re: Re: magneto trouble in reply to Larry from MD, 05-18-2004 09:26:29
Thanks Larry I'll check. Do you know of a reliable place for parts?
Larry806
05-18-2004 12:16:56
 Re: Re: Re: magneto trouble in reply to Bullrunner, 05-18-2004 10:55:07
I've had good luck in the past just call 1 800 magneto That's the Standard magneto co in Chicago
