Tractor Talk Discussion Forum
Fixing Leaking Thrd'd Insert, Cyl. Head
Paul
05-18-2004 12:38:11
Some previous owner put a threaded insert in the spark plug hole of a Kohler air cooled engine (aluminum I think). I'm loosing compression through the outer threads, Any way to fix this?
What about oil mixed with gas to purposly carbon things up? Thank you.
Bob
05-19-2004 08:25:48
 Re: Fixing Leaking Thrd'd Insert, Cyl. Head in reply to Paul, 05-18-2004 12:38:11
If you can't seal it up with a new spark plug gasket, a machine shop can remove the Heli-Coil and drill and thread the head for a solid repair bushing.
Paul
05-19-2004 16:05:58
 Re: Re: Fixing Leaking Thrd'd Insert, Cyl. Head in reply to Bob, 05-19-2004 08:25:48
Thanks for the ideas everybody. I drilled a hole in a beer bottle cap, and used it as a washer to expand the "footprint" of the plug past the thrd'd
insert. I put muffler cement on the underside as a sealer. Seems to improve compression. Will it last? We'll see!
Chuck
05-18-2004 18:30:46
I have never had great luck with heli-coils in heads some work,some don't. Originally should have had a lock tite type sealer to keep the insert from leaking and coming out. You could try to redo it if it is loose or I would try to find another head.
Thomas
05-18-2004 12:46:50
The seal should be on the top face, not the thread. Threads are not air tight unless coated with compound / plumbers tape. Try fitting a new washer to the plug or a new plug?
