Tractor Talk Discussion Forum
john deere 70
dave
05-20-2004 12:52:34
Does anyone know how many quarts of oil for the engine in a john deere 1953 model 70 gas???? also how to drain the oil? Thanks
buickanddeere
05-20-2004 13:54:30
 Re: john deere 70 in reply to dave, 05-20-2004 12:52:34
Link
Scotty
05-20-2004 13:51:14
Crankcase should hold 11 quarts! (according to I & T shop service manual # JD - 10). There is a drain plug on the bottom of the Oil Pan that has a brass seal ring on it. The nut takes a large wrench (I think about 1 1/4 - 1 1/2" by memory). The oil change is more effective if You run the tractor for several minutes at a higher RPM to get the dirt mixed up in the oil, & drain it warm, or hot! I always refill the air cleaner while I am at it! The nut to remove the oil filter is located on the bottom close to the oil pan. It has a round protruding lid about 6" +/- across with a nut in the center. Be careful when removing!!! I cant tell You how many times it fell in a 5 gallon bucket, & splashed all over me! The filter popps straight down. The gasket will probably be stuck in the grove that the lid fits in!
