Tractor Talk Discussion Forum
VA series tractors
pasbon
05-21-2004 05:04:08
I have located 3 va series tractors, 1 VAI and 2 VA.One va is for parts,the other VA was running but doesn't have much compression, the VAI developed a knock and was shut down. the sheetmetal has some rust holes through it and the tires are in need of help. are there enough parts that are interchangeable on these to make it worth while? The VA for parts and the VAI both have stuck engines. they are in the '48 - '50 range. the owner said make an offer, what are they worth?
mj
05-21-2004 22:03:05
 Re: VA series tractors in reply to pasbon, 05-21-2004 05:04:08
Offer him 2 or 3 hundred and see what happens. You can always go up....Roger?
Jim.UT
05-21-2004 13:46:49
Last year a neighbor sold a VAC with bushhog mower for $1200. It ran and looked good, but not restored. That's all I know about Case VA series values.
