Tractor Talk Discussion Forum
Fuel line question
Garry
05-21-2004 06:30:39
I am missing the diesel fuel line from the filter to the injector pump on a Case tractor. Can I put a rubber line as replacement? Will it cause any problems? I am also thinking of inserting an electric fuel pump there also. I should be able to get it running after getting this connected.thanks for any help
Chris
05-21-2004 07:48:30
 Re: Fuel line question in reply to Garry, 05-21-2004 06:30:39
I do not know why you could not use a rubber fuel line from your fuel pump to the injection pump. That is what I run from my lift pump to the injection pump on my Allis and it has worked for years. Use a fuel rated line not just any rubber hose. I think that is what the other reply was shying you away from.
Garry
05-21-2004 08:03:59
 Re: Re: Fuel line question in reply to Chris, 05-21-2004 07:48:30
thanks Chris, that makes the job much easier with a flex line. I will get a fuel rated line.
Adam B.
05-21-2004 20:04:23
 Re: Re: Re: Fuel line question in reply to Garry, 05-21-2004 08:03:59
An auto parts store (like NAPA or Advanced Auto) or performance parts store (like Summit Racing Equipment) should be able to get you a line that'll work.
Aeroquip is a brand name, with hoses for about any application you can think of for transferring liquids and gases. I think you'd want to spec something safe for fuel, pressure-rated, and flame resistant. If you find an Aeroquip supplier, you should be able to buy your selected hose in bulk with a price per foot. Then pick out the connectors you need to match your tractor's fittings and the hose you're going to use.
Coloken
05-21-2004 06:50:33
What model? "rubber" no way. What ever they make them out of these days, OK. I am more worried that with the line missing you have gottn dirt or such in the pump. Any small stuff is bad for pump. Thats why they use 2 filters and then a 3rd final filter. Put the primer pump back befor the filters and mess with the last part only when you have too.
Garry
05-21-2004 07:00:25
 Re: Re: Fuel line question in reply to Coloken, 05-21-2004 06:50:33
I recently replaced the injector pump so no trash in there. I need some type flexable line if possiable since the pump is about 3 inches above the fuel filter. The line will look like a "Z". This is a Case 530 tractor.
