Tractor Talk Discussion Forum
John Deer Model B clutch noise
Kevin Koler
05-23-2004 18:37:04
Hi - I have a old B that makes kind of a high pitch nose when the clutch is engauged and the tractor is in gear (under load). If I pull the clutch in it stops. If I hit a bump the noise will kind of bounce with the tractor. Is there an adjustment I should make or is it normal. Thanks Kevin
Pappy
05-23-2004 22:40:02
 Re: John Deer Model B clutch noise in reply to Kevin Koler, 05-23-2004 18:37:04
One thing I would check is the bearing on the primary reduction gear shaft. This is under the small cover on the side of the big gear cover, to the rear of the clutch pulley. It's a small bearing, but can cause lots of noise and problems.
Stony Jim
05-23-2004 19:28:40
No, the noise is not normal. Check the pulley brake. It should not touch the pulley when engaged. Brake also may need relined. That's the one thing that pops to mind and easy to fix.
