Tractor Talk Discussion Forum
Carpenter Bees
Matt S
05-25-2004 06:16:33
What kills them, and where do I buy it? Lowe's doesn't carry anything. These things have found my barn, and are starting to do some damage.
john d
05-26-2004 20:48:07
 Re: Carpenter Bees in reply to Matt S, 05-25-2004 06:16:33
Mix some Sevin powder into water for spray. Follow directions on container as to strength, procedures, and where NOT to spray the stuff. Coat the boards they like, and the carpenter bees will die. One application on their favorite spot in my pole barn worked for at least 4 or 5 years!
They'd show up in the spring, and within a day or two, be laying dead on the floor.
Bus Driver
05-26-2004 04:15:17
Dust some Sevin into the holes you can reach. They will carry it into the nest and it kills the babies too.
john in la
05-25-2004 16:00:44
Do not know how true it is but was told they will not drill in painted wood????? ?
worth a try.
GG
05-25-2004 19:05:26
 Re: Re: Carpenter Bees in reply to john in la, 05-25-2004 16:00:44
They will drill in painted wood, but not as bad! I have found that filling the holes with "bondo" and re-painting will slow them down, but some return.
Larry
05-25-2004 19:01:56
I have seen them drill in painted wood. I have also heard that if you put moth balls in nylons and hang them around, it will keep them away.
Dh in Carolina
05-25-2004 16:39:26
I use brake cleaner, works better than bee spray and is cheaper. When I got some extra time I use a pellet rifle. works real good and is a great stress releaver. DH
Scott TN
05-25-2004 10:33:59
I pay my kids or their friends twenty five cents a bee if they kill'em. I spray with lindane, it is a little oily and seems to stay around longer than other sprays. I have just repl;aced the face boards behind my gutters and they were all eaten up from Carpenter bees. This is war!!
John S-B
05-25-2004 10:15:56
I just use wasp and bee spray in the aerosol cans. The foaming kind works real well. Fill the holes with plasic wood filler.
Ben in KY
05-25-2004 08:51:09
MIx up a batch of poision ( pyrithin ? ) and spray the eaves and stuff where they hang out/drill. Do this about 3 times during the summer and you should be fine. I used to use Dursban but it has been restricted.
