Tractor Talk Discussion Forum
Top link adjustment for flail mower
Tom Lendt
05-25-2004 07:09:17
I just picked up a Mott Hammer Knife flail mower over the weekend to replace my rusted out bush hog and was curious as to the top link length. I've never used one of these before, so any input would be appreciated. Thanks in advance.
DuaneWKKC
05-26-2004 04:36:06
 Re: Top link adjustment for flail mower in reply to Tom Lendt, 05-25-2004 07:09:17
Use the back roller to coarse adjust the height, you can use the top link to fine adjust the height but I try to use it to keep the PTO shaft running level (angle should be split between the front -joint and the back u-joint).
Goood luck with it, I have an 88" Alamo and love it.
DuaneWKKC
Mike M
05-25-2004 09:03:59
The top link length adjusts the cutting height. Also the back roller on most have bolts with different holes to gain more adjustments. I think you will like those flail mowers as they don't throw stuff or get as busted up when hitting objects plus you can do finish type mowing as well as cut down high stuff if you have enough horsepower.
