Tractor Talk Discussion Forum
rebuilt cub motor puffs smoke when turning tractor
Bill from Senec
05-29-2004 18:54:11
Hi , Hopefully someone knows why this happens restored 1948 cub with rebuilt motor tractor seems to run fine but when i try two use the mower to cut grass and i make a turn the tractor puffs a little smoke could this be that the govoner is not set right i tried to set the carberator ,timing plus the govoner by the manual but sometimes it seems iam not getting full thottle on the gas lever tried to adjust that two as much as i can any help would be much appreciated thanks Bill
39caseR
05-30-2004 10:02:59
 Re: rebuilt cub motor puffs smoke when turning tra in reply to Bill from Seneca, 05-29-2004 18:54:11
Something else it could be is ,did you break in the engine properly?.
Paul Janke
05-30-2004 05:41:41
Is the choke maybe not opening all the way? What color is the smoke? Are you lacking or losing power?
Bill from Seneca
05-30-2004 06:36:26
 Re: Re: rebuilt cub motor puffs smoke when turning in reply to Paul Janke, 05-30-2004 05:41:41
tractor puffs blue smoke after turning the tractor but than stops it does this only after the tractor gets hot seems like iam lacking power because i have to have the throttle fully advanced plus it looks like the oil presure drops a little bit
John *.?-!.* cub owner
05-30-2004 07:29:53
 Re: Re: Re: rebuilt cub motor puffs smoke when tur in reply to Bill from Seneca, 05-30-2004 06:36:26
Blue smoke normally indicates oil burning, are you sure you don't have it ovefull on oil (3 quarts). Also is the oil filter cup overfull. Another possibility is the carb float level, though it usually is black smoke.
Bill from Seneca
05-30-2004 18:44:27
 Re: Re: Re: Re: rebuilt cub motor puffs smoke when in reply to John *.?-!.* cub owner, 05-30-2004 07:29:53
Ok does black smoke mean the tractor is getting to little gas with the carb float adjustment or to much thanks Bill
Stan(PA)
05-30-2004 19:57:02
 Re: Re: Re: Re: Re: rebuilt cub motor puffs smoke in reply to Bill from Seneca, 05-30-2004 18:44:27
If it's black smoke, it's running too rich. Too much gas..... ..Stan
