Tractor Talk Discussion Forum
narrow front end
tony
06-02-2004 17:09:26
i wanted to klnow if anyone knows why the tires on a narrow front end are closer at the top than they are at the bottom towards the ground what was the reason for this
Allan
06-03-2004 11:13:02
 Re: narrow front end in reply to tony, 06-02-2004 17:09:26
third party image
Hi Tony,
Here is what I feel is the proper adjustment for a tricycle front end. That door should never come open.
I've heard rumors to the effect that tricycle front ends make great boat anchors too. :>)
Smile,
Allan
buickanddeere
06-02-2004 20:33:56
They have caster to has a tendency to self steer straight. The camber makes steering easier by getting the two tire to ground contact areas closer together. Also helps keep mud squeezed and then dropped out.
Gene Davis (Ga.)
06-02-2004 18:28:56
Sounds like the bearings are torn up or just missing.They should be closer at the bottom than at the top.
Red Dave
06-02-2004 17:33:41
tony, all the narrow front tractors I've been around have just the opposite, closer at the bottom, farther apart at the top.
tony
06-02-2004 20:09:49
 Re: Re: narrow front end in reply to Red Dave, 06-02-2004 17:33:41
you are right they are closer at the bottom i miss wrote but why is that what was the purpose
Sam#3
06-03-2004 08:06:09
 Re: Re: Re: narrow front end in reply to tony, 06-02-2004 20:09:49
Now that you're on your feet(grin) ALL steering gear is built with caster including your automobile products. It may be more noticeable when the wheels are so close but stand back and look at a properly alighed standard front you'll see the same tilt.
paul
06-02-2004 23:37:19
Several reasons.
MUCH easier to steer when they are as close as possible on the bottom.
Keeps the steering from wobbling.
Mud falls out as it rises up the back side.
--->Paul
