Tractor Talk Discussion Forum
Harry Ferguson T30
brooks holder
06-03-2004 20:06:22
ihave a Harry Ferguson T30 and having trouble with it running. Today we worked on the t30. we replaced the voltage reg. and the other part attached to it. but not fix the problem. the tractor wants to surge while running. we put new points,plugs, solonodie rebulit starter, and still haveing the problem. Does any one know what it good be the problem? Thanks and God bless to all.
Ray,IN
06-04-2004 20:28:31
 Re: Harry Ferguson T30 in reply to brooks holder, 06-03-2004 20:06:22
Like Fred said, you really should buy an owners manual from a MF dealer. The Ferguson governor is quite touchy and if any one of the adjustments are wrong ,yours, and many other symptoms appear.
Jerry/MT
06-04-2004 18:02:18
There is an adjustment screw on the timing cover housing (left side of engine)that damps the governor. Screw it in very slowly, 1/4 turn at a time, and see if it helps the problem.
í Ú Ç
06-04-2004 16:09:14
ÃäÇ í Ú Ç
Fred OH
06-04-2004 10:20:08
Sounds like you need to buy the tractor manual so you'll know how to check out the different systems on it. It appears to me like the governor is out of adjustment, but not knowing the rest of the story...you better check out the three filters in the fuel system. One in the tank, one in the settlement bulb assembly, and one in the elbow on the fuel line where it goes into the carburator. Take the line off at the carburator and if it doesn't "pee" a good stream...blow it out with an air hose...but first remove gas cap and stuff a clean rag in opening so you won't get gasoline all over you. Report back if you found out anything positive or otherwise so someone can help you further. Fred OH
