Tractor Talk Discussion Forum
do i need a coil
Hank
06-05-2004 14:57:31
I have a 8n tractor can't get it to crank changed wires,plugs,points.Sometimes i have fire on the plugs and sometimes it sparks 2 or 3 time.Do i need a coil,or is their a way to check my coil.
hlwilliams@conninc.com
George
06-05-2004 15:53:57
 Re: do i need a coil in reply to Hank, 06-05-2004 14:57:31
Could be you condensor, too.
Is there any pattern as to spark/no spark? Hot, cold, wet, dry, etc.
Not sure how an 8n distributor is set up, but on most there is a insulated feed through (usually phenolic fiber) going from the points through the distributor housing -- I have seen this insulator breakdown so that it would short out the points intermittently. A lot of times you will see this happen in high humidity conditions.
