Tractor Talk Discussion Forum
farmall h spark plugs
tony
06-06-2004 16:06:35
i have a 1942 farmall h when i buy new plugs the tractor runs almost perfect, but the longer it runs the worse it runs especially under load it will run good at a idle but when you give it gas or try to go in high gear it misses once you get up to speed it will clean out and run on all cylinders also when this starts happening the plugs are black. when i change the plugs again it will run good for a while then start this all over am i getting the wrong plugs. or what else could it be.
dw
06-06-2004 19:30:10
 Re: farmall h spark plugs in reply to tony, 06-06-2004 16:06:35
If you are using Champion Plugs, try Autolite or AC.
Ron
06-06-2004 16:42:46
If, just after you change plugs, there is no black smoke out the exhaust, the plugs are a couple of heat ranges too cold or you have the wrong thermostat or worse yet are running without one. There is nothing wrong with the carburetor.
If you have black smoke, then yes, the carburetor is adjusted too rich or the float level is too high. It does not need to be rebuilt.
Nor. Al
06-06-2004 16:37:21
Tony the other post is correct ,it is too rich of fuel , but before rebuilding try adjustment screw in the bottom of carb bowl it will have a tap to lock it from turning,loosen tap and try turning it 1 round and see if it still runs under a load. clean plugs or replace before doing this.
DL
06-06-2004 16:10:50
Too much fuel... rebuild your carb!!!!
tony
06-06-2004 18:46:40
 Re: Re: farmall h spark plugs in reply to DL, 06-06-2004 16:10:50
i did rebuild the carb!!!
DL
06-06-2004 20:41:26
 Re: Re: Re: farmall h spark plugs in reply to tony, 06-06-2004 18:46:40
double check your float settings... also, check the fuel/air adjustment screws... sounds like you're getting WAAY to much fuel!
UncleTom
06-06-2004 18:37:19
Yes, it is to rich and it is fouling the plugs or sooting them up which. Then they wont fire.
Nor. Al
06-07-2004 04:27:54
 Re: Re: Re: farmall h spark plugs in reply to UncleTom, 06-06-2004 18:37:19
You are correct fuel mixture too rich I've been there -done that with an "H" a number of years ago.
