Tractor Talk Discussion Forum
Case 400 Series
Tammy
06-09-2004 08:15:08
We have this old tractor, according to everyone we've talked to it's a 1955 Case 400 "series" (they always stress the "series" part??) Has the round front end, and 2 heads. When we got it, it didn't have the starter or the fuel pump, and thank goodness we found that, and it does run, but it doesnt really want to start on its own, my husband says it needs the internal compression release?? But once we have it going it runs good but my husband says we either have a bad injector, or a dirty injector, this tractor supposedly was not run for at least 7 years when we got it. If anyone happens to know anything about this model tractor, I've heard there wasnt many of them made....?? Is that true? If so, what is the approximate value of it? Any info would be appreciated. Thanks Tammy
R-man
06-13-2004 05:54:50
 Re: Case 400 Series in reply to Tammy, 06-09-2004 08:15:08
Tammy, I have a 1955 400 also. These are fantastic tractors but they do not start the greatest. Make sure your battery and cables/connections are in tip top condition. It also helps to have the cracking pressure of the injectors set 300 lbs. higher than stock. After that it should start ok down to about 30 degrees. Anything less than that will probably require starting fluid. Case tractors are popular here in S.E. WIS. Good luck
