Tractor Talk Discussion Forum
2010 JD roosa master no fuel
Mike Rose
06-11-2004 22:13:33
Any inf. on a roosa master fuel pump would be appreciated. I have the line in the pump, lined up with #1, dot lined up with the dots, filter bled off return line bled off. Still no fuel to injectors ,lines all the way off no fuel Inf. on repair manual would be helpful Thanks Mike
The tractor is a 1965 2010 JD deisel last of the lot. ssn# 69196 It was a backhoe at one time.
trying to get her going.
jdemaris
06-12-2004 05:15:54
 Re: 2010 JD roosa master no fuel in reply to Mike Rose, 06-11-2004 22:13:33
Just adding to what was already stated - make sure the shut-off valve is not "shut-off." That can also stick and it's easy to get to (the shut-off metering valve is under the three-bolt cover).
Mike
06-12-2004 16:07:24
 Re: Re: 2010 JD roosa master no fuel in reply to jdemaris, 06-12-2004 05:15:54
I will check it out. Three bolt cover Ok on the fuel pump itself?
Thank You
Bob
06-11-2004 22:32:56
Has the unit sat for a long time without running?
The plungers inside the pump can gum up with old diesel fuel, and stick in the inward position, so they do not move outward to take on a charge of fuel. A little know-how and a $30.00 seal kit can get it going, or probably $300.00 to $800.00 at the pump shop.
Mike
06-12-2004 16:17:15
 Re: Re: 2010 JD roosa master no fuel in reply to Bob, 06-11-2004 22:32:56
No it's been running but very badly though. I just bought it. I tore the motor down. Two broke pistons and blown head gasket. Head has been reworked. the fuel pump shaft came out when I dis. the motor I didn't want to get into it so I bought some seals for the shaft lined up the marks put it back together but no fuel coming out of the inj. lines.
Thanks Mike
