Tractor Talk Discussion Forum
starters in general
maxpayne
06-12-2004 08:40:56
what causes a starter to drag when it gets hot?
RAB
06-12-2004 13:18:15
 Re: starters in general in reply to maxpayne, 06-12-2004 08:40:56
starters should not generally be run long enough to get hot. They are only rated for intermittent use and the user manual often advises on the maximum run duration and minimum rest times.
Regards, RAB
Coloken
06-12-2004 09:08:43
Common thing is worn bearings that allow the armature to drag on the field pieces.
Paul Janke
06-12-2004 11:12:35
 Re: Re: starters in general in reply to Coloken, 06-12-2004 09:08:43
Maybe this is because the armature gets bigger because of expansion of the metals at higher temperatures?
UncleTom
06-12-2004 13:54:05
 Re: Re: Re: starters in general in reply to Paul Janke, 06-12-2004 11:12:35
If the bushings are worn allowing the armature to drag against the ironcore inserts,then the magnitism pulls the armature event tighter against the field iron cores robbing all the powr from the starter. UncleTom
