Tractor Talk Discussion Forum
Double checking fill procedure.
Loren, Thanks D
06-17-2004 21:48:06
Haven't seen it in the book yet and I see no other option but want to make sure filling the trans/diff. on a 300 U is through the plug just under the floorboard on the left side. Fill till it runs out like most rigs? Loren
txblu
06-18-2004 05:54:25
 Re: Double checking fill procedure. in reply to Loren, Thanks Dave., 06-17-2004 21:48:06
Worked on a 300 for a friend once but don't remember the fluid fill access ports.
When you said fill till it runs out, I want to clarify something for your benefit.
If you have a fill port on the side of the main tractor housing and it is just below the centerline of the rear axles then what you said is probably true. (Course that would make filling awkward.)
But if your fill port is on top of the housing, you have a full plug somewhere along the side of the housing that is approximately just below the center line of the rear axle. Gear trains and hydraulic systems(of which I am aware) do not run completely full of fluid. A power steering pump might run pretty close to full, but not the main tractor sumps, nor cars, nor trucks.
Mark
