Tractor Talk Discussion Forum
How much weight on a 135 loader
Ben
06-19-2004 11:23:54
I have a Massey 135, how much weight would it lift up if i put a loader on it? would it lift say 300kgs? half a ton? I really dont have a clue on loaders! Any help would be appreciated.
It has water filled rear tires, I can add weight.
Thanks Ben
Tommy D6-8U
06-19-2004 12:19:16
 Re: How much weight on a 135 loader in reply to Ben, 06-19-2004 11:23:54
Ben,
The loader should handle 1/2 ton or so with water in the rears, but I would be careful with the front end on the 135. These axles were really not designed to be used on a loader; they'll work but heavy use is not recommended. The thrust bearings on the bottom of the spindles are a little light for loader duty.
Tommy
ben UK
06-20-2004 04:06:05
 Re: Re: How much weight on a 135 loader in reply to Tommy D6-8U, 06-19-2004 12:19:16
Tommy, I have a UK 135 with straight axle - is that better for loader work or make no difference?
Thanks
Ben
Tommy D6-8U
06-20-2004 05:46:45
 Re: Re: Re: How much weight on a 135 loader in reply to ben UK, 06-20-2004 04:06:05
Ben,
It definitely should be better. The adjustable "agriculture" type just was never really intended for loader work. The fixed axles have heavier spindles and thrust bearings in them I believe. Maybe bigger hubs and wheels too.
Tommy
