Tractor Talk Discussion Forum
Motor grader head gasket
tom
06-20-2004 05:05:42
I have a Champion 710 A motor grader with a 5.9 L cummings engine.I replaced the head gasket and now cannot get all the air out of the fuel system.I do not know where the bleed valve is on the injector pump or if even has one and the book I have does not show that pump.It has Bosh and the lines go in the front of the pump and our book shows a pump with the lines on the top.I have bleed all filters and when I pump using the manual pump no air is detected up to injecter pump.Would you know where to bleed this pump.I have cranked this engine way to much already and all I get is air at the injecters.Anybody know where is start to remove this air.The engine was running before I removed the head(just replaced head gasket because of leak.Tom
higgins
06-20-2004 07:17:45
 Re: Motor grader head gasket in reply to tom, 06-20-2004 05:05:42
what kind of shutoff you got cable or electric?
tom
06-20-2004 15:12:41
 Re: Re: Motor grader head gasket in reply to higgins, 06-20-2004 07:17:45
electric,but how would that cause Air??Thanks for your reply.Tom
tom
06-20-2004 15:16:25
 Re: Re: Re: Motor grader head gasket in reply to tom, 06-20-2004 15:12:41
To add:I removed the fuel line going to tank and used a 1 gallon can and it almost cranked,had smoke and also had someone bleeding the injecters at the same time but never got it to crank.Still getting plenty of air at the lines on pump lines
