Tractor Talk Discussion Forum
bush hogging position control lever setting ?
Chuck Grandgent
06-20-2004 13:36:03
Do I want "position control" (position control lever vertical) or "constant draft control" (position control lever horizontal) when bush hogging ?
Jerry/MT
06-20-2004 19:25:21
 Re: bush hogging position control lever setting ? in reply to Chuck Grandgent, 06-20-2004 13:36:03
You want psition control because you want to hold the "hog" in a fixed position relative to the tractor.
Jeff Leavitt
06-20-2004 13:55:04
You want the load and depth selector in the depth or position selection. When bush-hogging you really SHOULD NOT encounter any draft. How big a bush-hog do you have and what do you charge?
Jeff
chuck grandgent
06-20-2004 16:36:52
 Re: Re: bush hogging position control lever settin in reply to Jeff Leavitt, 06-20-2004 13:55:04
Thanks Jeff. Moved here (Alachua, Florida) in February, so now have 7 acres and a Ford 8N tractor plus 60" Woods Brush Bull to mow it with. Not sure how it's SUPPOSED to behave, so don't know if what it's doing is right or wrong.
paul
06-20-2004 19:04:02
 Re: Re: Re: bush hogging position control lever se in reply to chuck grandgent, 06-20-2004 16:36:52
Draft mode is only for heavy pull loads, pretty much only plowing with a mounted plow.
--->Paul
