Tractor Talk Discussion Forum
1962 Ford 600 timing mark?
Ken
06-24-2004 18:38:00
I need the point gap and where do I find the timing mark on a Ford 600, 4 cylinder, 34 hp gas tractor?
Thanks Much, Ken in Omaha
Stan(PA)
06-25-2004 05:57:30
 Re: 1962 Ford 600 timing mark? in reply to Ken, 06-24-2004 18:38:00
Timing mark is on the flywheel. There is a hole you can see the mark through. Your's may or may not still have the cover in place. Point gap is .025
By the way, if it's a 600, it is not 1962. If it is 1962, it's a 601 series. You can check using the serial number list in left hand column on this page. Above info applies in either case. Good Luck..... .Stan
