Tractor Talk Discussion Forum
Benefits of higher compression?.
Jonathan
06-26-2004 08:32:41
Hi, I would like to know what the benefits are to running a higher compression gas engine?. I know with higher compression, I would need to run a higher octane rating to prevent detonation, but I have also heard over and over compression = horsepower, but I was wondering just how it creates horsepower?, is it from the gas being compressed more for a more efficent burn?, or just why is there a big benefit from running higher compression?. Thanks in advance!.
buickanddeere
06-26-2004 20:40:03
 Re: Benefits of higher compression?. in reply to Jonathan, 06-26-2004 08:32:41
Bob M and Neil have the compression ratio info down as well as anyone there. More CR lets the engine (a mechanical device) extract more energy from a unit of fuel by increasing the expansion ratio. It's why the later steam engines were "compound" with a 2nd larger cylinder on the exhaust of the primary cylinder. Extreme spark ignition compression ratios allow the exhaust valve to be opened early to improve cylinder purging/breathing without losing power on the power stroke. And having more fresh airful mixture in the combustion chamber with less exhaust residue. Combustion and steam turbines can be very efficient due to thier expansion ratios being many time more than a reciprocating engine. On large ships a steam turbine was aften attached to the exhaust of the multistage piston engine to wring the last bit of heat/pressure from the steam.
Jerry/MT
06-26-2004 17:46:25
Increasing the compression ratio improves the thermal efficiency of the engine because it raises the peak cycle temperature. So for a given displacement(cubic inches, liters, whatever) your specific fuel consumption is improved. However, you don't get something for nothing. The you need higher octane fuel, stronger components, better materials to withstand the higher temperatures, etc, etc.
Additionally...Jerry/MT
06-26-2004 18:08:08
 Re: Re: Benefits of higher compression?. in reply to Jerry/MT, 06-26-2004 17:46:25
I should have said that for a given displacement engine, increaseing the compression ratio will give you more power and thus reduced specific fuel consumption.(Remember the sprk ignition engine runs at essentially constant fuel to air ratio so if the engines have the same displacement, they will have the airflow at a given rpm and hence the same fuel flow.) The pressures and temperature will be much higher at the end of the compression stroke in the high compression engine.(ideally, compression pressure = atmospheric pressure x (compresion ratio)^1.4 where 1.4 is an exponent) if you compare ideal presures for a 6.0 compression ratio to say compression ratio 8.0, the ideal pressure at end of the compression strokeis approximately 50 % greater. The temperature are also significantly greater. And we haven't ignited the mixture yet! sot he peak pressure and temperatures are much higher so the force on the top of the piston is very greatly increased and that's what makes the power! hope this helps you.
Neil
06-27-2004 00:04:40
 Re: Re: Re: Benefits of higher compression?. in reply to Additionally...Jerry/MT, 06-26-2004 18:08:08
Cool! I like it when we get scientific. Assuming the same displacement, it is indeed the increased cylinder pressures throughout the power stroke that cause the increase in power with increased compression. As you pointed out an engine with 8:1 compression will, theoretically have 50% more peak pressure (around top dead center) than an engine with 6:1 compression ratio. As the piston progresses down the cylinder the difference between the pressures decreases until they are virtually identical at bottom dead center.
In order to determine how much more power will be made we need to determine how much higher the pressure in the higher compression engine is on average during the power stroke. Which is the same thing as saying we need to determine how much greater the thermodynamic efficiency of the higher compression engine is.
Unfortunately, it seems I threw out my thermo book the last time I moved. Fortunately, the internet is a wonderful place and you can find an explanation of compression ratio and thermodynamic efficiency at the following website –
Link
As you can see there the equation for thermodynamic efficiency is:
1 – 1/(r^(k-1))
where:
r = compression ratio
k = Cp/Cv (which = 1.4 (you’ll just have to trust me on this one (thanks for the assist Jerry, I wouldn’t have remembered what it was otherwise))
Plugging and chugging, we arrive at the following theoretical thermodynamic efficiencies for various compression ratios:
4:1 – 42.6%
5:1 – 47.5%
6:1 – 51.2%
7:1 – 54.1%
8:1 – 56.5%
9:1 – 58.5%
10:1 – 60.2%
11:1 – 61.7%
12:1 – 63.0%
13:1 – 64.2%
14:1 – 65.2%
This is also shown graphically on the above-listed website.
Now, to find the theoretical increase in power from one compression ratio to another, one divides the thermodynamic efficiency of the higher compression ratio by the thermodynamic efficiency of the lower compression ratio. For example, to figure out the theoretical increase in power from a 6:1 compression ratio to a 8:1 compression ratio, one divides the thermodynamic efficiency at 8:1 (56.5%) by the thermodynamic efficiency at 6:1 (51.2%).
56.5/51.2 = 110.4%
Thus, the theoretical increase in power by going from 6:1 compression ratio to an 8:1 compression ratio is 10.4%.
The theoretical power gains for each of the 1 point jumps is listed below
4:1 – 5:1 = 11.5% power increase
5:1 – 6:1 = 7.8% power increase
6:1 – 7:1 = 5.7% power increase
7:1 – 8:1 = 4.4% power increase
8:1 – 9:1 = 3.5% power increase
9:1 – 10:1 = 2.9% power increase
10:1 – 11:1 = 2.5% power increase
11:1 – 12:1 = 2.1% power increase
12:1 – 13:1 = 1.9% power increase
13:1 – 14:1 = 1.6% power increase
It should be noted that the theoretical power increase is also the theoretical torque increase.
It is also worth mentioning that the equation for the theoretical increase in torque for a displacement increase combined with the necessary head and cam work to fill those extra cubes is considerably simpler - it is the new displacement divided by the old displacement:
New Displacement/Old Displacement
Thus, while a 33% increase in compression ratio (from 6:1 to 8:1) will yield a 10.4% increase in torque, a 33% increase in displacement coupled with the appropriate intake work will yield a 33% increase in torque.
Ron
06-27-2004 03:05:35
 Re: Re: Re: Re: Benefits of higher compression?. in reply to Neil, 06-27-2004 00:04:40
The problem with theories is that they aren't real. For example, aeronautical engineers use certain "theoretical formulas" to determine flight characteristics. Problem is, according to them, bumblebees cannot possibly fly. Good thing the bumblebees don't know that! Remember that the next time you fly; these are the same guys that designed your airplane.
Even back in the '60's during the muscle car era engineers got 10% torque improvement per point of CR increase. Like I said, it's a very general rule, subject to lots of factors. One factor that entered into this that 104 octane gas was available anywhere. As you moved up the CR scale, you got those excellent gains because the high octane prevented knock and therefore power loss. There were some muscle cars than ran CRs as high as 11.5:1.
Another example: the perfect blower motor has a static CR of 8:1 or so. By adding 6-8 lbs. of boost, most supercharger manufacturers will claim a 30% boost in torque... and it just so happens that 6-8 lbs. of boost raises the combustion pressure to about the equivalent of an 11:1 compression ratio. Remember, engines don't "see" compression ratio. They see cylinder filling and therefore combustion pressure.
Jerry/MT
06-27-2004 20:10:15
 Re: Re: Re: Re: Re: Benefits of higher compression in reply to Ron, 06-27-2004 03:05:35
I used to work in the aircraft industry and I would like to see the reference that says that the bumble bee can't possibly fly! I hear people say that, but I'd like to have the name of the person who proportedly said that. Can you supply the name or a reference? Hell I can fly a brick supersonic with a big enough engine!
Neil
06-27-2004 08:46:27
Well, we're just going to have to agree to disagree on this one. It's my opinion that this theory is pretty close to reality and really gets to the core of the issue. As I mentioned I think I remember a dyno test that showed numbers very close to those theoretical numbers once. But I don't have it anymore and can't tell you where it is so it's all just hot air really.
If anyone has any GOOD dyno numbers (sorry guys I don't trust the stuff you wrote down off the bouncing gauge on the M&W while you were trying to read the conversion wheel in your left hand) on the matter I'd certainly be interested.
buck
06-26-2004 12:01:52
all good points thus far but lets look at in a little different fashion. Say for a given engine that at 6:1 that engine will generate 100 psi compression but you take say 50 thousants off the head and it is generating 150 psi compression and the ratio is now 8:1. Logic tells us that the 150 psi will generate more power than the 100. Now enter the fuel factor or higher octain. Considering octain as the resistance to burning then the higher octain will burn longer in the cylinder therefore keeping more pressure on the piston during the power stroke. As someone else mentioned continue this process and you have a diesel. I caution that without considering ignition,fuel delivery,air flow,ignition and valve timeing that this one process may be counter productve. We get a lifetime out o our old tractor engines. The NASCAR guys get one race and John Force gets one pass on the quarter mile.
Stan(PA)
06-26-2004 11:03:55
If you're like me, you want it in simple terms, so here goes.... Think of a rifle. There is a certain amount of energy in the powder charge. If you load the shell, but put the slug at the very end of the barrel, it will basically fall out when you pull the trigger. If you slide it down halfway into the barrel, it may travel 25 yards. When you have it crimped into the shell, it exits the barrel with deadly force. The tighter you are to the gas expansion force, the more initial energy is exerted on the bullet or piston. This is simplified, and not exactly accurate, but it should clear it up for you..... Stan
Ron
06-26-2004 10:18:06
You should be aware of one thing though..regular "Pump Gas" will only stand a Maximum of 9.0 to one CR , and in a "Lugging Condition" like a tractor is usually under, it will have to be even less than 9.0 or you will get detonation.. For reliability, 7.5 to 1 CR is about the limit in a real "Working Tractor"...
Bob M
06-26-2004 09:41:04
A somewhat simplified explanation:
A fundamental thermodymamic characteristic of the Otto cycle (4 stroke, spark ignition) cycle engine is this: The higher the compression ratio (CR) the higher the "expansion ratio" (the opposite of the CR) during the power stroke. The higher the expansion ratio, the more energy that is extracted from each power stoke. The more energy that's extracted, the higher the engine efficiency. And the higher the efficiency, the more power that is produced from a given engine displacement. Hence all things being equal, higher CR = higher power.
The downside is higher CR's result in higher stress on the engine (both mechanical and thermal), increased problems with detonation, ect. Simply increasing CR to increase power is not exactly a "free lunch"!
Ron
06-26-2004 09:35:52
Thanks for asking such a thoughtful question. That's what makes this group such fun.
Whenever you compress a gas (air/fuel mixture here) you heat it. The greater the compression, the more heat; the more heat, the more power. Remember, it's the expansion of the air/fuel charge as it burns that drives the piston. So yes, in that sense, it is more efficient. This is exactly how diesels work and why they are more efficient than gas engines.
As you have observed, the heat from higher compression ratios must be managed. Should the cylinder become too hot, spontaneous combustion (knock) occurs and power is decreased... if continued too long, you start breaking parts. Octane enhancement is only one way of managing spontaneous combustion. See>Link
for>Link more information.
Your point about horsepower is true but far more important is the enormous low rpm torque improvement in higher compression engines. I was a kid in the '60's when there were lots of cars sporting 400-450 ci. engines running as high as 11:1-11.5:1 compression ratios. Many of these engine made over 500 lb./ft. of torque and the acceleration was mind-blowing.
For tractors, torque is all that matters. And the more torque you can build at low engine speed the better. Higher compression ratios are the best way to make more low speed torque. An old rule of thumb is that for each full point you gain 10% in torque. For example, going from 8:1 to 10:1 should net you about a 20% torque gain.
txblu
06-27-2004 05:18:46
 Re: Re: Benefits of higher compression?. in reply to Ron, 06-26-2004 09:35:52
Good verbs Ron. I like to dig into subjects also. Like you said, makes you think and that is the fun part of participating on this site.
Mark
Jonathan
06-26-2004 18:11:59
Wow, and thank you sir for taking the time to answer my question. I checked out the KB piston page you posted, I'll be able to get alot of information from that!, lots of cool technical stuff.
Thanks alot!.
Neil
06-26-2004 10:44:45
Well, I have to be cantankerous again (seems that's the only time I bother posting). 10% per point is very optimistic when you're talking 8:1 and higher. You'll probably get 10% (or more) going from 5:1 to 6:1. But I've heard more like 4% increase per point when you're in the 8:1 - 12:1 range. In fact, I read that in an article in a magazine (Car Craft I believe it was) wherein they actually tested it by stacking head gaskets to go a point at a time from 8:1 to 12:1. As best I recall it ended up showing about a 4% gain per point.
I just have to say that in my opinion compression ratio is very over-rated for increasing power. As I alluded, I suppose it makes sense up to around 8:1 where you can get by on regular gas. After that, if it were me, I would take the extra money you would spend on race gas for a compression ratio increase and spend it on more bore and stroke or making your heads flow better or putting a better cam in it.
Jonathan
06-26-2004 17:49:53
 Re: Re: Re: Benefits of higher compression?. in reply to Neil, 06-26-2004 10:44:45
I know the latest craze in the car magazines is stroker engines, however, my brother in law told me strokers required using thinner bearings in order to have clearence enough so not to hit the sides of the block. What he told me is stroker engines were pretty short lived due to the thinner bearings and needed rebuilding after every summer if you used it hard. I also heard strokers had overheating problems and the risk of making the cylinder walls too thin and too weak. I see in MMFF (Muscle Mustangs And Fast Fords magazine) there are blocks availible that have grooves cut in the sidewalls of the block to allow clearance for the rod bolt heads. This is in their latest issue on pg.135, so I'm only guessing that unless you were to either have your old block modified for clearance or possibly buy a new one that has been designed for a stroker, you'd have to use thinner bearings.
thanks!
Neil
06-26-2004 22:45:49
 Re: Re: Re: Re: Benefits of higher compression?. in reply to Jonathan, 06-26-2004 17:49:53
Well, there's a lot to discuss in this post.
I'll start with thinner bearings. I think what you're actually referring to is thinner rod journals, which is the part of the crank shaft that the connecting rods attach to. It is definitely the case that a stroker crank puts the rod journals closer to the block. In some cases, that means that it is necessary/easiest to provide clearance between the rods and block by going to a thinner rod journal.
For example, many of the kits that are out there for stroking a Ford 460 to a 514 reduce the rod journal from the factory 2.5" diameter to a diameter of 2.2", which makes it easier to get the rods to clear the oil pan rails without doing any grinding. Does this have an adverse affect on engine longevity? Well, it's hard to imagine how it could improve the longevity. Thicker rod journals would make the crankshaft stiffer, which would reduce wear by keeping things aligned better. Also, thicker rod journals provide a larger bearing area to absorb the loads that compression and inertia forces put on the rods. The ultimate questions are: 1) how much will a given reduction in rod journal diameter affect engine longevity; and 2) how much reduction in engine longevity is acceptable to you to gain some power.
Most of the time what you have to do is consult with someone that has a good understanding and/or experience that will enable them to arrive at a durable combination of stroker components. Let's talk about the Ford 514 example again. The 2.2" rod journal that is used on the stroker cranks happens to be the stock dimension on a Chevy 454 crankshaft, which is an engine that is very similar to the Ford 460 in basic layout and power production. Most would surmise that if 2.2" is sufficient to provide adequate reliability in a Chevy 454, it's probably going to live pretty well in the Ford 514. Ford simply indulged in a little overkill with 2.5" rod journals.
The other thing to consider is that not all stroker combinations will require smaller rod journals. Sometimes there simply is a lot of extra room in the block. You can also gain clearance in some situations by going to rods that are made of a higher quality material and have less material surrounding the crankshaft. For instance, the big end of a steel rod can be made smaller than a cast iron rod because the steel is stronger. Thus, it is may be possible to go to a steel rod with less material around the rod journal and clear the block without having to go to a reduced rod journal.
The other way to avoid having to go to smaller rod journals is to have grooves in the block as you mention. That's not really a big deal - it just takes a little time in the machine shop. And it really doesn't have much detrimental effect on the durability of the block. The parts of the block ground on to clear a stroker crank don't typically see much stress. (I guess I should qualify this by saying that this is the case in car applications. In tractor applications where the engine block functions as the frame of the tractor, there likely is much more stress on the oil pan rails. But it's my guess that you'll also find tractor blocks have a lot more room in them such that you can likely get more stroke without grinding or reducing the rod journal diameters.)
I don't have any hard data on how stroker cranks and reliability, but I think your brother-in-law is overstating the situation. Of course I don't know if he is talking about people that put together sensible combinations or people that are pushing the ragged edge (as I understand it there are guys out there in antique tractor pulling with stroker crankshafts that are welded together - that's not good for longevity and they know it).
To make a long story short - if you talk to a competent engine builder about putting together a stroker combination, you'll probably be able to arrive at a substantial (at least 10%) increase in displacement without sacrificing much in the way of durability.
You also mention increased risk of overheating with a stroker engine. Well, yes, with the possible exception of increased compression ratio, almost any time you increase the power, you are also going to increase the amount of heat rejected by the engine and you'll need to think about upgrading your cooling system.
You also mention the possibility of making the cylinder walls too thin and weak. Here you are referring to boring the engine as opposed to stroking it. And, yes, one always has to consider how much extra material there is in the block when deciding how much boring can be done. With a lot of passenger car engines the default answer is 0.030" overbore is the max. A Ford 460 being a good example - the service manual says that the block can only be bored 0.030 over. So, a conservative individual would not bore the engine more than 0.030". There are plenty of engines out there, however, where there is plenty of material to allow boring the engine without causing durability problems. Heck, as best I understand many of the tractor manufacturers themselves offered larger sleeve and piston combinations when rebuilding engines.
As with deciding on whether/how much to stroke an engine, all you really need to do to find out whether/how much you can safely bore an engine is consult with a competent engine builder.
As for boring an engine creating overheating issues, like stroking the engine, increased power will cause increased cooling demands. Other than that I don't believe there are any peculiar cooling issues created by boring an engine.
One other thing to consider is that almost any increase in power is going to reduce engine longevity if you use it. An interesting bit of information I learned working at a heavy truck and diesel engine manufacturer is that the best predictor of engine wear, oil deterioration, etc. is not hours of run time, revolutions of operation, or miles logged - it's gallons of fuel burned. Of course the sharp advocates of increased compression ratio will point out that an increase in compression ratio would result in more power with the same or less fuel and thus, theoretically, more power and greater longevity. And that might be true, as long as you make sure to stay away from detonation. Detonation will easily reduce the life of an engine far more than a modest reduction in rod journal diameter, rod/stroke ratio, or piston compression height.
I guess the biggest thing I would want to make clear is that I'm hesitant to say that a compression ratio increase will yield "big" power and/or torque gains. I'll put it this way - if you and I take identical tractors, you do nothing but increase the displacement 10% and I do nothing but increase the compression ratio 10%, your tractor would whip mine.
Jonathan
06-27-2004 07:14:32
 Re: Re: Re: Re: Re: Benefits of higher compression in reply to Neil, 06-26-2004 22:45:49
I am now seeing why stroker engines are so popular. I really couldn't understand why everybody wanted them in their street cars if they weren't very durable, and needed to be rebuilt after being driven over the course of 1 summer. Excellent examples of the Ford 460 journal thickness compaired to the chevrolet 454, that was what got me to best understand just how durable strokers are. My BIL who told me about strokers isn't an engine builder or anything, he just told me what he had heard somewheres. By the way, you don't happen to know of any web pages with sound clips of engines would you?.
Thank you!.
Neil
06-27-2004 08:59:23
 Re: Re: Re: Re: Re: Re: Benefits of higher compres in reply to Jonathan, 06-27-2004 07:14:32
Finding engine sound clips on the web is somewhat tough. I've found a few soundclips/videos of various types (5.0s, tractor pulls, a supercharged 540 Chevy), but I don't know where I found them anymore. If you'd like, I can email you what I've got.
Ron
06-27-2004 02:41:59
Lots of good info.
A couple more points. While I come from the same school, I've learned over the years that it's usually far more cost-effective to replace an engine with one that has a larger displacement than get into boring and stroking the old. This is more true with car/truck engines where certain engine families have a range of displacements. Some tractors do to. Example: I can buy and rebuild a 454 Chev and swap it into any engine bay a 350 came out of for less than just the cost of a custom 350 stroker crank and machine work. And the bigger engine will always be more reliable than the smaller one.
Some tractors also present these swapping possibilities. Olivers are especially good. I realize than some sanctioning bodies have rules that preclude such swaps.
Actually there are some engines where boring results in huge overheating problems. Siamised cylinder engines already have cooling issues due to no coolant flow between adjacent cylinders. Boring them is usually not done. Most tractor engines are wet sleeve designs and most tractors have enormous reserve cooling capacity so they are good candidates for boring.
I agree with your statement about the 10% inprovement in general but there are other factors. I can shave the head of an inline 6 tractor engine for say $400. Because they are usually low compression engines, I can pick up 10% easily. To get a 10% increase with a bore/stroke might cost 10 times that $400. Lastly, there are about a dozen factors that enter into engine performance. They must all be balanced. For example, with a bore/stroke, the intake and exhaust systems must be modified to increase flow. This can get mighty pricey depending upon the exact situation. The one big advantage of compression ratio increases is that because they increase efficiency, they often produce excellent torque gains with no other modifications though some engine builders in some situations will run a longer cam to help eliminate the dreaded low-rpm part-throttle knock.
Neil
06-27-2004 08:37:31
 Re: Re: Re: Re: Re: Re: Benefits of higher compres in reply to Ron, 06-27-2004 02:41:59
Ron,
First, let me say you really do know your stuff, which makes this discussion so much more worth while than otherwise - there's nothing more frustrating than debating with someone that is too ignorant/dumb to understand what you're saying.
You mention that it's smarter to swap to an engine that has more cubes than to bore and stroke a smaller one where possible:
AMEN, AND THANK YOU!!
I never cease to be amazed at the desire to spend $15,000+ on a 454 small block. You can easily put together a better 454 big block for far less $.
To the extent that it's possible, the idea to swap to a bigger engine is the right one for tractors as well. Of course, my general modus operandi would be to find a bigger engine to swap in and then bore and stroke it.
As for boring and overheating, I'll admit I kinda glossed over that one. It's true that I am not aware for certain that it causes overheating or in what circumstances it will. On the other hand I've heard various rumblings that it will cause overheating.
I suspect most of the reputed problems are, as you mention, with siamesed bores. I'm guessing it's more of a problem with localized overheating of the material between the cylinders and not the engine as a whole. Of course, if the material between the cylinders is too hot, you've got a problem regardless of the temp. of the rest of the engine.
I don't know how big an issue overheating with siamesed blocks is, as I've never really had the opportunity to get good information on that subject (and boy would I like to). Maybe someday I'll find out as I'm currently lusting over GM's Ramjet 502, which uses a siamesed block, for daily driver use. I guess GM provides a warranty with it (though I don't know how long). My guess is that due to temperature gradients, the cylinders run a little more out of round than a "regular" block and cylinder wear is advanced. And I've not heard whether or not you can do a clean-up bore of 0.030 or so on that block.
I'd say that you're almost certainly right that compression ratio increases are usually the cost effective way to get the first 10-15% increase in torque. And I must admit that if I was building a tractor, one of the first things I'd probably do is bump the compression ratio to 8:1 or so - it just makes sense.
I wouldn't consider it a technique to get "big" power or torque gains, though.
Also, I say compression ratio increases are usually going to be more cost effective because it seems that displacement increase can be pretty cheap sometimes too. This seems to be particularly true where guys swap in larger cranks/pistons from the same engine family. The Minnie Mo guys come to mind first. It seems every time I'm on that board there is someone asking about putting X crank in Y block.
Ron
06-26-2004 12:27:09
I actually agree that "law of diminishing returns" enters into it. If you'll visit the site I posted previously they explain the factors quite well. I think I even mentioned that when you start to see spontaneous combustion, power drops off very quickly.
But compression ratio increases and forced induction are by far the best ways to increase low end torque and of the two, compression ratio increases are usually cheaper and less troublesome to obtain.
Neil
06-26-2004 16:45:30
 Re: Re: Re: Re: Benefits of higher compression?. in reply to Ron, 06-26-2004 12:27:09
Well, it sounds like we're largely in agreement over the objective factors, but maybe differ on the subjective aspect of what's "best." And the fact that we can differ on what's best is what makes this country great.
I definitely understand your point about bang for the buck. It's pretty darn cheap to have the head milled or put an lp head on or swap out pistons. And it's generally less troublesome indeed than forced induction.
I, however, come from the "no replacement for displacement" school. In my opinion, there's no better way to add low end torque than to add cubes. Yes, as far as the cost of parts and machine work goes, it's more expensive than a compression ratio increase. But, if you use the tractor for more than a few tractor pulls a year, you would want to factor in any additional cost for higher octane gas. With fuel costs factored in, one can imagine that there are certainly situations in which boring or stroking would be more cost effective than a CR bump.
Of course, in the case of most antique tractors the compression ratio can be raised from the factory level without requiring any upgrade in fuel. In that case it most certainly makes sense to increase the CR at least to the point where it is as high as it can go without needing to upgrade fuel.
At the end of the day I suppose it's all a matter of personal preference as to how one prefers to waste one's money. ;-)
