Tractor Talk Discussion Forum
Kubota L2550 clutch problem
Bob Crowley
06-28-2004 07:58:00
I'm a guest here so excuse me if I bruise protocol
I have a borrowed Kubota 2550.
I was using it to move some loam the other day and suddenly lost all forward and reverse capability.
My Buddy whom i borrowed it from said it had been dripping some transmission fluid recently.
So far I have done the following: Refilled the transmission (which took about 20 quarts) Tested with all possible drive configurations (to eliminate the stupidity factor)
Checked the bottom side for anything which might have become disconnected.
The Kubota dealer (Larry at East Elliot Garage in Elliot) said the clutch is probably gone but given that it happened with none of the usual signs of a worn clutch ($1500.00), I am wondering if it is possibly something else..... .....and hopefully something cheaper.
Any advise would be greatly appreciated.
Thanks,
Bob Crowley
Chris
06-29-2004 06:41:44
 Re: Kubota L2550 clutch problem in reply to Bob Crowley, 06-28-2004 07:58:00
I have the shop manual for that tractor, if you would like I can scan and email you the pages on the transmission so you can see what is in there and maby find out how to fix it. How many hours? Shuttle or GST? 4x4? Chris
ADelaire
01-12-2006 16:39:48
 Re: Re: Kubota L2550 clutch problem in reply to Chris, 06-29-2004 06:41:44
My L2550 just did the same thing. Did you find something other than a new clutch? I was hoping it would just be a bad safety switch or low on fluid.
