Tractor Talk Discussion Forum
Wobbly Tire
JeffK-MN
06-28-2004 20:22:37
Great Web sit I have learned alot. Now I have a Oliver 1800 B that has a wobbly rear right tire only in fast speeds when I go slow you don't see it. I have checked all the bolts and all are tight. Any way to check for bent rim or shaft? The shaft is keyed how would I make sure that the tire is stright? Thanks Jeff
JMS/MN
06-28-2004 21:38:47
 Re: Wobbly Tire in reply to JeffK-MN, 06-28-2004 20:22:37
On many rear tractor tires, there are bolts and funny-shaped cast lugs that hold the rim to the center 'wheel' of the tractor. There might be eight of them on each wheel, maybe more. If they are not tightened evenly, the wheel will appear to wobble at high speed. Those cast parts are eccentric, and if not tightened evenly- they wobble. Not to worry as long as all the bolts are tight. Watch for slippage, and rust or worn marks on the rim- then they are not tight.
