Tractor Talk Discussion Forum
HELP-Dynahoe
Charlie
07-05-2004 08:49:48
HELP is the word, I think I have been stiched up with a Dynahoe I just bought.....1974 190-4 Dynahoe.
Problems.
No brakes.
Not enough forward drive to hardly pull it's self along even in low ration. Max revs needed to get it to move at all.
All advice needed happy to call anyone who can help me as well???
Charlie
Elwood M. White
04-16-2005 12:14:47
 Re: HELP-Dynahoe in reply to Charlie, 07-05-2004 08:49:48
I do have a e-mail address, emwhite@suscom.net and Ph. 717-244-8497. If I can help in any way please feel free to contact me.
Randy Widdoss
04-02-2005 17:55:51
charlie, how did you make out with your trans??
i have the same problem with one i just bought.
thanks for any help you can give
Randy
Amy D. Moore
08-10-2004 11:12:18
I found brake parts at Moody's:
1-800-869-4517
Someone had hacked out one master cylinder on my machine and put a T connection in to make one master cylinder push both brakes. Of course, there's not enough capacity to really stop the machine and the one leaks like a sieve.
Don't know much on the tranny - except to make sure it is full of fluid.
If all else fails and you'd like to sell some parts - someone on the forum is looking for your sticks, and I'd love your pressure relief valve!!
Elwood M. White
09-09-2004 14:00:46
 Re: HELP-Dynahoe in reply to Amy D. Moore, 08-10-2004 11:12:18
I have what I believe to be a 1971 Model 160. I have problems keeping brake fluid in the master cylinder. I purchesed a new master cylinder but the cylinder goes dry. I also did a dumb move and broke the dip stick Hyd. Cylinder. The casing is broke and I'm looking for a replacement. Any help with the Hyd. cyclinder would be greatly appreciated.
Gary Guinn
08-17-2005 19:53:13
 Re: HELP-Dynahoe in reply to Elwood M. White, 09-09-2004 14:00:46
Hello, I just bought a 160b
Please don't laugh. I do NOT see a brake pedal
UNLESS, the only other pedal besides the gas pedal is the brake. I THOUGHT it was the clutch.
Any words of wisdom would be appreciated.
thanks
Gary Guinn
Willy Murphy
10-05-2005 17:55:31
 Re: HELP-Dynahoe in reply to Gary Guinn, 08-17-2005 19:53:13
Im thinking two brake pedals, two master cylinders
because only rear two wheels brake to stop 6 or 7
tons. each with a pedal and masters. Seperate Systems..for all that Iron. Have you tryed going
down hill with the Front Drott bucket full of rock
mud...Ive had to dig in to brake do to brakes failed.
