Tractor Talk Discussion Forum
Front Axel - F250 SD with Powerstroke, SRW
farmall300u
07-05-2004 13:03:12
I read on this forum that Ford changed the front axel from a Dana 50 to Dana 60 11/02. Well guess what, my truck was made 11/02. How can I look at it and tell if it is a Dana 50 or 60?
T_Bone
07-06-2004 10:43:40
 Re: Front Axel - F250 SD with Powerstroke, SRW in reply to farmall300u, 07-05-2004 13:03:12
Hi farmall,
Your probably talking about a post that I made and it seams I made a mistake. The date cut off is mid 11/01. So your 11/02 would have the D60.
Look on the low right side of the differential face cover and there should be a 60 stamped in the face.
If the orginal Ford part number tag is still attached, the part number will be 248 for the D60 and 224??? for the D50. I'm not completely sure of the 224 number.
T_Bone
Mike M
07-05-2004 17:20:21
My dodge has a dana 60 frt and rear and they are marked with a number 60 cast into the housing edge I think on the opposite side of the diff. cover.
