Tractor Talk Discussion Forum
shorted out wiring in Ford f250 -sweating in texa
bill huddleston
07-08-2004 20:31:43
i have a 89 ford f 250 thathas a short in the ac compressor/ blower wiring. it all started when i moved the selector from off to ac. i heard a pop and later found that the blower fuse under the dash had melted. i replaced the blower motor with no change. the fuse still melts when i move the the selector from off to ac or max or defrost. i took the switch out of the console that controls the fan speed and the heat and cooling/heating and tested them and they appear to be working properly. both leads to the ac compressor show to be grounded on my ohmmeter. i think the switch in the steering coloumn is where the short is.
what i think i need is a wiring diagram for an 89 ford truck so i can wire around the ignition switch in the steering column to see if that is where the problem is.
any body got a wiring diagrm i will pay for copying and your trouble
any other ideas. oh yeah, the blower will work at all speeds if i leave the climate control selector on blower. thanks for your concern. bh
Dan in Wisconsin
07-09-2004 04:17:40
 Re: shorted out wiring in Ford f250 -sweating in in reply to bill huddleston, 07-08-2004 20:31:43
The Haynes repair manuals have some fairly decent wiring diagrams. The Chilton diagrams are not as good or they are not included at all at times.
